Central locking locks if only bootlid is opened
If i unlock my car using the central locking remote, and then i open the boot, the car locks within about 30 secs and i have to press the button again.
Its as if it doesn't realize a door has been opened and so locks itself unless a side door is openened.
I find this really annoying and potentially a huge problem if you put the keys in the boot whilst loading and then shut the boot youve locked your keys in!
is this normal behaviour or is there a fault somewhere?
The bootlid was changed a while ago and it still does it so cant be a faulty lock
I reckon this is either a failed switch in the boot lock or a broken wire between tailgate and body.
Nope - they do this as standard.  You have to open/close a door before opening the boot if you want it to not lock. :)  It will know the boot is open, but it will not stop the auto-locking - and to my knowledge there is no way to stop it either.  Certainly not a VCDS option.
ah ok just an annoying thing i'll have to put up with
Shame as rest of car is so good
Mine doesn't do it. The car stays unlocked with boot open.
Here we go chaps, I made a video (there is no audio because I forgot to turn the mic on).
I unlock the car with the remote.
I open the boot.
I stand for over a minute - the car does not re-lock itself.
I open the driver's door to prove it.
https://www.youtube.com/watch?v=fIpDm9Wazjs
Edited by TMB
I open the boot.
Thank for that video, mine locks itself after about 30 secs whereas yours stays open
I think there must be a problem somewhere
I know its not with the boot locks or wiring as ive replaced the entire tailgate & all the wiring and it still does it
Must be the central locking controller if there is one
