Rear lights
Hi.I have 07 octavia vrs..just activated fogs as daylights with carista and now my rear top and bottom sidelights don't work either side just the little capless ones...any idea how to put them back on please.would post pic bug can't see how that's if you can...tia
Any help PLEASE....just failed mot because not all working
What happens if you revert the setting you changed in Carista?
Have you tried contacting their support to find out what happened?
If you can, get a VCDS autoscan done and posted. If Carista did mess something up, VCDS can probably fix it.
Might be worth adding where you are and checking the VCDS section for any local members who have it.
Yes I've reverted back but still not on.not hot vcds....fuses all OK. Changed bulbs but no power to bulb holder...I'm Scunthorpe, lincolnshire
No codes at all.carista say it's not there software so at a loss.just want it to pass mot
With all computer controlled devices that work incorrectly, I just remove the power for a while and then reboot.
Have you tried disconnecting the battery for half an hour?
Edit. You will probably have to reset the electric window lifts afterwards by holding the switch in the open then closed positions for a few seconds once the window stops. Repeat for other windows.
Edited by pikpilot
Not tried that I will give it a try
I used Carista to activate my front fog lights as DRL's on my 2008 Octavia estate and didn't experience the issues you describe.
Something isn't quite right here. Was anything else altered at the same time?
Edited by silver1011
No nothing else altered it's strange...it does have a town bar on of that's done anything..not one electrics it's one of those can bus relay boxes a mate put on hor me? ...had battery of for nearly a hour and still same
Did try coming home lights but it did nothing as I've no light/rain sensor so turned ito off again
