Top mounts
Afternoon all . I'm trying to solve my front end knocking over bad road surfaces ... All the front end suspension parts are replaced less then 8.000 ago . But I'm thinking top mounts maybe failing, is there anyway to check these whilst struts are on the car !!
Regards Tony
Not easily I don't think.
Try jacking the car so the wheel is around 1cm clear of the floor. Stick a pry bar under and lift up pushing the wheel up. Do that on and off and listen for noise.
Drop links can easily fail before that mileage.
I fitted meyle hd drop links . So I hope it's not them . Although will look . Much easier to change them ;)
Oh right. Worth checking anyway :)
