Philips X-treme vision led 360
They work great on my FL as sidelights but I did disable the bulb checks.
Bulb checks???
Bulb checks???
If I remember correctly I got bulb out warnings as they aren't CAN-bus friendly.
To fix it I disabled the bulb checks (cold diagnostic/warm diagnostic) for them which sorted it. I'm not sure if something similar needs doing on the pre-FL :)
Could you attach the code for bulb check disable langers2k?
If I remember correctly, I changed address 3092 from 0x01 to 0x81 and address 3093 from 0x13 to 0x73.
It's not possible using VCDS, you'll need something that can directly edit the BCM EEPROM such as ODIS-e or VCP :)
Thanks I'll try finding someone local or nearer, thanks for all the info so far.
