retrofitting H7 projectors
I have a 2009 preface fabia 1.4 TDi, born with H4 headlamps, i bought a set of projectors so i could fit xenon, all went well installing them BUT, when i put the high beam on, its shorting out.
The shutter opens fine(but is shorting, ALL lamps in my cluster is blinking when i use high beam), and the bulp goes out :(, i have tried to wire the projector directly to ground and high beam, but its still the same, when i retrofit other cars with chinese projectors the wiring goes:
GROUND = Everything that needs ground, here its the H7 bulb and the projector
H4 Low beam+ = On the H7
H4 High Beam+ = on the projector, so when i set it to high beam it will open the shutter.
BUT, when i do this it shorts the car :(!
has anyone done this conversion?
No One? :(
I have projectors on my 60 elegance and If I am right the projector is dipped beam and the H7 on its own is full beam.
Maybe try changing it round?
Edited by JGrindel
There are only h7 only lamps for the preface :(
