Front windshield wipers
Hi
I have any issue with my front windshield wipers working intermittently.
I can eventually get them to run in fast speed after driving for a few minutes but will constantly stop and then wont start again when I turn them off.
I have replaced the motor,checked the linkage,replaced the CCU but still the same fault.
I checked voltage at the connector block to the motor and can only seem to get 6V?,however I can then plug it back in and it works sometimes?
Surely it needs to be 12V?
Anyone have any suggestions?
Thanks in advance
Maybe the wiper switch?
I would double check the fuses. I had a similar issue and it was one of the 3 fuses that control it.
Thanks for the replies. I will try and check the switch.
I will replace all 3 fuses aswell.
Could be a earthing issue
I can't remember if the motor is earthed with a separate earth cable on the mounting point?
If not and it's earthed through the multiplug/loom you can try putting a temporary earth wire from the multiplug to the body of the car
The fuses haven't changed anything unfortunately.
I will try a temporary earth lead from the plug.
Does anyone know how to test the stork?
Can the plug connector be taken apart and the terminals removed?
  • Sponsor
Hi
Thanks in advance
When you say you've changed the CCU, which unit do you mean, the one that looks like this, or the one that looks like this?:
Hi
The first one. the eBay item pic.
Is that the right one?
  • Sponsor
Don't think so, no.
I'll just check some wiring diagrams, but I don't think the ebay link one has anything to do with the wipers.
The one you've changed out is mostly concerned with the door locking systems; no function to do with the wipers as far as I can see.
Edited by Wino
Thanks, I hope I got the wrong one
Quick update
Replaced the unit shown in the picture above,works now!
Thanks wino for the info.
All the searching I had previously done seemed to point at the unit above the clutch pedal as shown in the eBay pic above.
  • Sponsor
Good news. Thanks for letting us know the outcome. :thumbup:
Yeah nice to see someone appreciate the help given on here and let us know the outcome :)
