VMAXX coilovers and droplinks
Fitted my VMAXX coilovers and droplinks today and just wondered what the best way to set the drop links is? Any rule of thumb? I've gone 12 threads off the bottom on the fronts so went for the shortest droplinks but as for the adjustment it's currently on equal threads each side of the adjuster rod.
Also was wondering how many threads should be showing above the top mount nut?
Well, thought I'd update this-
Top mount nuts- just went until it was tight and then added 1/4 turn.
Drop links- 4 threads showing each end of the lock nuts.
Thread height setting on coilovers- 5 from the bottom on the front and two from the bottom on the rears as I found the back looked too low.
Got to say that the car rides very nicely only a little firmer than standard and much better in the corners. I also replaced all nuts and bolts along with top mounts and bearings. Next up is laser alignment
Edited by Jase009
