I want to make my turbo flutter
Hi have a 1.2 tsi Monte Carlo and I want to make my turbo flutter, is this possible? Please help
If you are refer to wastegate chatter
I don't think you can due to it having an internal wastegate
Would require modification
After searching it looks like it's pretty harmful for your turbo as it's essentially the compressed air being shoved back into the turbo and being 'chopped up' making that noise, causing a slow painful death for the turbo.
correct, not a good idea as it causes turbo bearing failure... its the reason you have a dump/diverter valve :thumbup:
Edited by DamoR
