Front speakers for fabia
I have posted this in ICE section but had no luck
Been looking through other topics over the last few days and I currently have the whole interior out of the car including door cards
Was thinking about upgrading front components I know the sizes which I need however I just don't know which to choose there is that many
Going down the amped with crossovers and speakers in oem places
Can anyone shed some light on a good set even a kit
What kind of rms should I be looking at ?
Should I put a setup together my self or buy as a full kit with everything I need
Looked at a rainbow kit but stated that amp output was only 30w rms which seemed a bit crap
I don't want to spend too much and don't need the best that can be bought
I don't know how much should be spent to get a decent set up either
Thanks sam
30W RMS is plenty of power for the smallest room in your house (i.e. your car) as long as the speakers can actually handle it.
Don't get hung up on numbers, a 50W Marshall into a 2 x 12 cab will make your ears bleed if you crank it right up, a 100W Marshall into a 4 x 12 will damage your hearing permanently.
I did read through your topic duck thanks
And my head unit states it's 4x50w will this mean 50w peak power ?
And can't remember who posted it but it was recommended between 100-150 rms for the front components I personally thought that was high but I don't know much about ICE
just enjoy the music
Thanks sepulchrave
Yes they will fit directly in to existing with the new adaptors in the picture and the connector housing should be the same for the original wiring loom I don't know how they will perform with the tweeter being so low down in the door also it only states the peak power not constant (rms) so you may be under powering them running from the h/u
If you do get these you may want to disconnect the tweeter in the top part of the door as these have one built in
Someone with better knowledge maybe along with better info than I can give
Hope it helps anyway
Edited by Picko98
I do have a old Sony amp xm444 4 channel amp
Which will output 80 rms when bridged to two channels
do I need to match the speakers to this or just get as close as possible ?
Just make sure the amp output doesn't exceed the speaker capability and don't forget that the impedance matters, still chuckling at the 600W peak comedy rating on those JVC speakers posted above, that's 425W RMS, not a snowflake in hell's chance they're rated for that.
i dont mind if the advert over sells them haha.. just as long as they're definitely a decent bit better than the standard ones in my 2004 1.2
Yes the impedance is 4 ohm at 80w bridged so should I get something that is as close as possible around 70 - 90w as I imagine underpowered speakers won't be too good either
Thanks sam
