Dash board failure then abs light
Hi guys please help ! ,,
I'm a time served mechanic that works in a German car specialist however I've never come across this I'm not the best with electrical side I'm more a nuts and bolts guy than a wire and sparks guy
I have 2 2008 Octavia estates both 1.9 tdi both cars were bought from a fleet company my wife's has a mere 225000 mile still on same clutch fly and turbo ???? With full service history is running excellent how mine has only covered a mere 126000 mile and is in major trouble
A few days ago while driving the dash went off completely all gauges speedo rev counter temp gauge the lot the lights and engine stayed running and the stereo and heater stayed on the low fuel/ low external temp buzzer went crazy this all lasted only a few seconds and then everything came back
This has happened a few times today but this time the srs light stayed on and while the buzzer was going crazy all the warning lights were flashing
I pulled over and turned the car off to find the dam thing would start and then cut straight out. I tried to lock and unlock the doors but still the same I left it sat for ten mins then she fired to life and I drove her home with the dash failing and the buzzer going maybe 3 times in a ten min drive
If any one has any ideas I would be greatful I've seen a lot of similar problems but with the mk1 saying needs a dash repair or replacement
I will upload a print out from vcds asap
Thanks to
check that the plug has not come loose in the back of the cluster
Any fault codes when scanned with VCDS?
Thanks for the support guys I've read with vcds and got loads of intermittent faults they are saved to lap top at work I'll upload later I'll also remove clocks to check connection and post updates
Iv had the same for two weeks and it's the cluster
Iv had everything checked and also had to leave it at least 15 mins after turning it of the auto electrician said there were loads of faults after a scan I took the dash board of very easy to do applied an electrical gel to the back but this is only temporary a fix for a week or so it comes back so it's of to get soldered seemingly a common problem.the beeping was driving me nuts starts just a few times the constant hope this helps and look forward to hearing of ur fix.there is pics on here some where about what needs to be soldered think it was a killer that was his name I have the pics but don't know how to or if I'm allowed to post
ok so a quick update did a vcds read and got loads of faults also did batterey and charge check she is charging at 14.2 volts unloaded and 13.8 loaded so charge rate ok however battery check showed a low charge in battery so cleared all faults and went for a 2 hour drive with minimal electrical use (i only do around 10 miles a day round trip to and from work maybe 30min max driving) and no problems then then yesterday did same with no problems i've ordered a bosch silver battery and gonna fit it on tuesday when back at work along witha set of glow plugs i do think that the cluster is the problem but a fault has shown wiyh the battery so it wont hurt
here is the list of codes from vcds
Thursday,29,December,2016,15:56:01:57797
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: TMBJS21Z482130273   License Plate: YT08TVL2
Mileage: 205640km-127778mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBJS21Z482130273   Mileage: 205640km-127778miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  9251
   Revision: --H07---    Serial number: SKZ7Z0H4730512
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6ADDBF52459E2C1277-803E
6 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 205289 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:38:12
             Freeze Frame:
                    RPM: 1134 /min
                    Speed: 1.0 km/h
                    Load: 20.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 205289 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:38:12
             Freeze Frame:
                    RPM: 1134 /min
                    Speed: 1.0 km/h
                    Load: 20.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 205289 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:38:12
             Freeze Frame:
                    RPM: 1134 /min
                    Speed: 1.0 km/h
                    Load: 20.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
005712 - Powertrain Data Bus
               P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 255
                    Mileage: 205423 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:15:06
             Freeze Frame:
                    RPM: 1449 /min
                    Speed: 51.0 km/h
                    Load: 53.7 %
                    Voltage: 14.52 V
                    Bin. Bits: 11000000
                    Torque: 244.0 Nm
                    Torque: 209.8 Nm
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 255
                    Mileage: 205423 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:15:06
             Freeze Frame:
                    RPM: 1449 /min
                    Speed: 51.0 km/h
                    Load: 53.7 %
                    Voltage: 14.52 V
                    Bin. Bits: 11000000
                    Torque: 244.0 Nm
                    Torque: 209.8 Nm
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 205540 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:46:07
             Freeze Frame:
                    RPM: 924 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.01 V
                    Bin. Bits: 11000100
                    Bin. Bits: 11000000
                    Bin. Bits: 00100001
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8B3E066E9C79BAF0-806A
1 Fault Found:
00474 - Control Module for Immobilizer
            004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 1Z0 820 047 K    HW: 1Z0 820 047 K
   Component: Climatic PQ35   140 0909
   Revision: 00140009    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 3B734A167A84659ADC-806E
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005434942
   Coding: 00880F030004140043110D000000000000087B075C000000000000000000
   VCID: 6FEBAE467E7CC93A20-803A
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 300108 022  0601
   Coding: 00055223
   Shop #: WSC 73430
2 Faults Found:
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 205540 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.35 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 88
                    Mileage: 205540 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1T042%
   Coding: 0020788
   VCID: 3D77440E64906BAAE2-8068
   Subsystem 1 - Serial number: 6332MSME2B256C29K
   Subsystem 2 - Serial number: 6342MSME34204039/
1 Fault Found:
            004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BM    HW: 1K0 953 549 BM
   Component: J0527           051 0100
   Coding: 0000002
   VCID: 7EF583022916B0B2BB-802A
4 Faults Found:
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 902 D    HW: 1Z0 920 902 D
   Component: KOMBIINSTRUMENT VD1 1620
   Revision: V1620056    Serial number: SKZ7Z0H4730512
   Coding: 0003401
   Shop #: WSC 07894 067 57207
   VCID: 35675C2E5CA0B3EA2A-8060
3 Faults Found:
00381 - Databus Instrument Cluster
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 89
                    Mileage: 205423 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:15:05
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 88
                    Time Indication: 0
01312 - Powertrain Data Bus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 205549 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:04:38
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K08201015D
   Coding: E9801F060002022303
   VCID: 3461612A57DAAAE21D-8060
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 88
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:46:07
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 88
                    Time Indication: 15
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 88
                    Time Indication: 15
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1620
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 89
                    Mileage: 205423 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:15:05
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000564
   VCID: 3879551A4BB24E8231-806C
No fault code found.
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.068 H08 1901
   Shop #: WSC 73430 000 90108
   VCID: 36655B2241A6B8F223-8062
No Faults Found
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Component:    KSG              0401
   Coding: 81D002007F2D8505085B010004CC
   VCID: 0009FDFA53E2C642C9-8054
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000564
   VCID: 397F501E70B8578ACE-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3H0011225
   Coding: 0000200
   VCID: 2E557342B9F680326B-807A
End-------------------------(Elapsed Time: 02:40)--------------------------
Address 03: DTCs cleared
thanks for the help guys
As you have 2x octavias
I would take out the cluster of the other car and try it in this one (it obviously it won't allow the car to start and will cause a few other faults) but if you clear the faults you can then see if you get the same faults due to not seeing the cluster.
You also have a faulty ignition switch, get that changed as the cluster requires a permanent and switched live
Thought of that but is only intermittent so unless I could swap dash and drive car for a few days it wouldn't help
I've found a company on net that will rebuild my cluster for £150 so if happens again I'll send it away
Ignition switch only put fault in after last time dash failed and no stating I read both cars regularly and that first time I've seen ot
You should change the ignition switch first
You can buy a used cluster on ebay for very little money. Also the cluster may be fine and you could have a wiring issue
Ok so quick update
Used car a lot over last few days done some really long journeys and so far no lights buzzers or anything all seems well scanned this morn with vcds and no codes anywhere apart from glow plugs so tomorrow I'll fit new glow plugs and a battery then fingers crossed
I've had exactly the same problem in the past.
Same faults occurred last year. The car would intermittently start but most of the time it failed to start. This was around a very wet time of the year and initially I thought it might be water ingress in the clocks.
Long story short, sent clocks away for testing with no faults found. Had them refurbished anyway as all my banging of the cluster had resulted in in an error on the Maxidot.
Car ran fine for ages and a few months back the fault occurred once again. Nothing since may I add.
Haven't replaced the battery in the car and touch wood it's fine at the moment. But the general trend on the forum seems to point to a battery issue. If it happens again I'll probably change the battery to eliminate that.
Good luck with the fix, keep me posted of how you get on.
Edited by TK699
Ok so this morning on way to work all hell let loose if any more lights had come on my car would have been visible from space
They stayed on for want seemed to be ages so in anger punched the top of dash and they all went out so not sure now which way to jump I think a battery as I now it's on it's last legs then if the problem still there I'll send clocks away
I did wonder about water as last year I had a cracked screen and I didn't get it replaced for a few months when I noticed I could push the screen out at the top corner with my hands and the floor on my side was wet I'll keep you updated thanks for the help guys
As I said before in an earlier post it's the cluster had the same for months
ok so finally changed the cluster got a used one from ebay luckily i know someone to code it in and put my correct milage in (used clocks showed 185k ive only done 130k) at same time changed battery for a bosch s40010 silver and a set of bosch glow plugs now its a matter of wait and see !!!!!!!!!!!
hopefully this will cure all faults as next service due in a few thousand miles and the cam belt is due also going to paris in it in may
