Fabia VRS Help
Pretty much I bought a Fabia VRS 107K miles and after a few days the headgasket went.. anyway after getting this fixed and getting the timing belt and waterpump changed at the same time, once I start the car and it is started the car wiil wobble/vibrate for legit a few seconds then be fine from then on. the car is due a service and is getting done this week could that be effecting it? it was not doing it before.
Any help or point in the right direction would be great, thanks alot  :angel:
you need vag com I would look at glow plugs first and then temp sender
could be fouled plugs, injection problem, timing out, sensor not reconnected properly, warped head or gasket not fitted correctly.
Is it on one cylinder or all?
