Oil in my intercooler
i put a induction kit on my octy vrs and then i drove for 5 miles then i gave it some and the tempture whet in the red i went home and by the passanger wheel there was oil on the floor can any one ne help me
Oil by the passenger wheel? Nowt over there but the gearbox.
If temps are going up sky high is there water in it? Fan cutting in? Water coming back through the small pipe on the header tank?
Sorry driver side the temp is up when i drive hard should there be oil in inter cooler?
There will be a bit of oil in the I/C
no theres quite a lot coming out if the seals in the turbo go were would the oil go?
If the seals in the turbo have gone oil will be everywhere, in all the inlet system and it will smoke as it burns it off.
ok its my seals do you know were i can get a TURBO FOR A AUQ ENGINE 51reg vrs?
