Key Transponder
Can a key from a donor vehicle be recoded to another ? If so what is required ?
The chips are supposed to be a "one time only" programming, you need to have the immob pin code ( dealer or VagTacho) then with the pin use VCDS to program the chip in the ignition or you can buy a separate chip programming tool that is just a read coil connected to the USB lead
Is vagtacho through the odb port ? Then use vcds again through odb port to code key ?
Yeah all done via the OBD connector, or I have another lead that you can code a key away from the car
Cool. What is the other lead called ? Where's best to buy from ?
So is it pretty straightforward ? Is s new transponder chip required ?
The chip can only be "written" once, so if your going to get a key from another vehicle you will need to replace the chip with a virgin one, then "write" the code from your immob into it either via the ignition switch reader coil or with that unit I linked to
Are both pieces of software required or wil VagTacho do it ?
You need the Vagtacho/commander  to get the immob pin code from the speedo, you then need VCDS or that stand alone set-up to code the chip
The links show those as 2 separate items no or I'm confusing myself ?
Yes they are different items, I bought the basic one first, to get the pin code, then decided to buy the second one that could code a key away from the car
Ok I have VCDS, so VAGTACHO and a chip and I'm sorted ? Any soldering required for the chip ?
