Retro Fit Cruise Control
Hi All
I'm new here and after some technical help if at all possible.  I have a friend who owns a yeti and he has asked me to do some research for him.
He is trying to fit cruise control, he has fitted the stalk and had an auto electrician put the required codes in but it still does not work, he's been told he needs a retrofit kit that contains a cable that is currently missing, is this correct? Can he not just run his own cable from the required pin on the stalk to the required pin at the ecu?
The yeti is a 5L, if you need anymore info just ask.
Nelix
