Oil breather tube on Fabia Mk2 1.2 TSI(2010)
Does anyone have the part number for the plastic part that connects between the top of the right hand side of the engine and the breather tube?The rather small nipple has broken off.Or where I can get one.Maybe comes as part of the tube.I've had a google but no luck.Thanks.
Edited by Rustica
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2011/drive_standart/697/hg_ug/103/subcategory/103042/part_id/2541369/lang/e
Item 21
Valve 030103175B
They cost around £16 in the UK
IMPORTANT! - see if you can retrieve the broken plastic bit that is probably lodged in the rubber grommet (item 24) that sits in the camshaft cover. The rubber grommet can be removed/prised out, but take care.
If you just push the new valve into the grommet, any broken part will be pushed into the camshaft area and can easily find its way under a camlobe. (I know from personal experience)
Edited by xman
Many thanks for that,Xman
