Turn fog lights off
Came in 3 nights ago from a foggy drive home with dip beam and front and rear fog light on. Turned off all lights (I don't use "Auto"). Yesterday morning I switch on the ignition and Maxi Dot tells me to turn the fog lights off - all lights were off at the time.
Question - as it is impossible to leave fog lights on if all lights are off what is Maxi Dot monitoring?
If the switch is at '0' then you should not be able to pull it out to switch on either foglights; if you leave the fogs on when you switch the ignition off it does give you a warning, but only for the rear fogs as far as I remember..
Sounds possibly a little glitch, try doing the same again and see what happens?
