CORNERING LIGHTS (FOGS)
Hello all,
The car is Octy f/l '09 and sometimes the cornering function of the fogs does not work.....I haven't noticed why, but it could be after a walk returning from ring road (speeds over 100 kph)and when reaching home in lower than 30kph  or out could be even when driving in town with such low speeds again...
After some hour it will resume itself without doing me anything and the cornering starts working normally...
This does not happen everyday.
The car is equipped with factory xenon headlights and rain and lights sensors.
I know system works at speeds lower that 40kph...
Any thought or idea would be appreciated.
Thanks.
I had this with my car, but i had to enable them with vcds to start with, i ended up turning them off and then coding it back on again, havent had any issues since then.
  • 1 year later...
Hello!
Do  you remeber to tell how to re-code via VCDS the fogs as for corniering function?
Thank you.
Regards
just untick the box save then retick the box save
If unsticking the option isn't necessary first to save and exit VCDS and wait some minutes before going to stick it again?
Remember which controller/byte?
