Coding of new steering wheel control module
Afternoon all,
About to change the steering wheel control module to a higline for mfsw retrofit. As the module is a new one, not previously installed in a vehicle, how do you code the new module? Does it come with anything on it (software, settings, etc). If not, is it a case of use vcds and code with settings taken from scan of original module?
Any advice or warnings, greatfully received.
Probably worth adding an autoscan of the vehicle in question.
Generally speaking, coding the lcode and adaption channels from the old module is a good starting place. You can then add any extras you've added :)
Langers2k,
Please see scan below. The replacement item is 1K0953549CD.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0573
   Revision: 00103 AF
   Coding: 48180AB8B05BB1C04008008011000024430000AE424D81605C4440000000
   Shop #: WSC 73430 790 00999
   VCID: 2D50862174DD3C294E-8078
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 29100  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
No fault code found.
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2GX9E.
   Coding: 0020788
   VCID: 3D70B66164BDACA9FE-8068
   Subsystem 1 - Serial number: 6332MSME4A4027075
   Subsystem 2 - Serial number: 6342MSME4C22293DJ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 0304009942D91A59C8-8056
There will be a pop up box with coding info when you open Coding option in address 16
I would go with 0000504 from your existing coding
Eddie, cheers for that. Once it gets here, I can crack on with the retrofits.
