Running as service/console version...
..seems to have an effect on the amount of points you can score.
Just wondered if there is anything behind this, as i now have (a lot more than i did)16 P4's @ 2.4Ghz upwards(mostly 2.8's) on 24/7 and now all running as service, with allow Big Wu's enabled.
Going back a few months i only had around 4 machines at most running, but they were running graphical client and my points per 24hr average was on a greater scale as you can see here:
Last 7 Months Production
Month <> Points <> WUs
02.06 <>1,269 <> 24 =52.82ppwua
01.06 <>20,948 <>272 =77.01points per wu average
12.05 <>8,116 <>33
11.05 <>10,108 <>30 =336.93Ppwua
10.05 <>10,526 <>45
09.05 <>12,026 <>45 =267.24 Ppwua
08.05 <>12,712 <>53
Just think somethings not quite right here, i would have thought so many P4's would have been giving a better 24hr average...
Any ideas? anyone
Apparently the service version is the most effective way to fold - I assume you have been allowing W/U's over 5mb ?
yes on all machines
why?
Basically, you get more points if you contribute more computing power to the cause. Because the larger units demand more RAM, processing one takes more power = more points
I've been allowing WUs of 5mb+ too, but I've had some pitiful ones allocated to me, and seen the computer only using around 9mb RAM against the fahcore78 task. :thumbdwn: The high scoring units tend to want to use 100mb ram, which is fine by me - its only a tenth of total power. I'm hoping its just a phase. :(
I think it's becuase my pc is getting all the big ones. I seem to get one everytime at the moment
Mine is currently working on a 19mb W/U ;)
cant understand it, i was doing an average of 200-350 points per work unit last year, if i was still doing that in January(see above table) i'd have made...
336.93Ppwua(in nov'05)X 272 (wu's in jan) = 91644.96points
instead of the pathetic 20948 i did get in jan
oh well:rolleyes:
Perhaps they've changed the points scoring system.
thing is having looked through some other users stats, they're still getting good averages *sighs
Maybe am just grasping at straws to get back my 10th spot LMAO
