Fabia vrs 1.9 pd130 idle judder
hello this might be a common fault or discussed before but I'm having problems with my fabia vrs pd 130 blt engine code.
when the vehicle is cold it idle fine but when car is at operating temp when sat at lights or stood still in traffic idling the car will judder intermittently if you  put load on the engine i.e. Turn on rear heated screen the car will idle fine is there any fixes for this please
Possibly the pulley on alternator has seized,it's a clutch type pulley and is quite common.
you need to remove the aux belt to see if the pulley is seized
