Foglight partially misted up
My left hand foglight has a band of condensation accross the mid section of the lense. How easy is it to remove the lense to dry it out. The car will be 2 years old in April. Joe
Don't think lens will come off
I would check for a small crack or chip
Do you use the fog's at all if not then then turn them  on for a bit to help dry them out
Don't forget driving with fog's on when not foggy gives you extra 20bhp so I'm told
Ran the foglight for a longish run moisture has disappeared no obvious chips so will just keep an eye on it thanks for the suggestion Joe
