New 12' Superb owner. Tire pressure sensor help w new wheels
How's it going gentlemen?  I'm a new Superb owner. Just took ownership of a 2012 Superb 1.8 tsi 6 speed manual.
I have a set of 18" Audi wheels w 245/40/18 tires that I'd like to put on the Skoda instead of the current 17s.
Been searching the web about the tire pressure sensors on these cars. So I need to purchase and install new sensors on these wheels? Or can I reset the system after mounting the new wheels/tires?
thanks for the insight and advice. Have a nice day
Joe
Just reset after fitting the new wheels/tyres. Not sure if there'll be enough clearance for the 245's but no doubt someone who knows about these things will be along shortly.
Dave
Thanks for the help. I was hoping it was a simple solution not involving buying and mounting new sensors etc.
I have read and read on the forum but can't get an answer to the 245/40 question. Anyone know?
wheels are 18x8 et 42
tires are 245/40/18
There are no sensors - it uses the ABS to detect loss of pressure by picking up the change in rolling radius.
tires are 245/40/18
In diameter there should be no problem, since this is with 653mm a bit smaller than the 657mm of 225/50R17, a dimension which is used successfully by quite some people on this forum.
The width of both tire and rim is most likely a problem. 235 seems to be the absolute max. But I'm no expert, I'm a fan of the standard 205/55r16.
Thanks again. I've also searched google etc for examples of 235/40 tires working. Not much out there actually. Doesn't seem to be a big car for customization. There's just bunches of them here in Denmark and I can't stand being one of the flock.
The 245s I have now will be tested just for fun. I'll measure it out from there.  Maybe get lucky and 235s will work. Any Picts or link from any of you?
Joe
