Disconnected police siren unit, now problems
Hi all, after looking around for a recent inside water leak I found the old police siren still in the car with the wires going through the fire wall gromit with a big hole
only after disconnecting it, chopping wires that didn't look connected, put the battery back on and now the steering light, traction control light and tyre pressure/rotation light are all on
power steering is not affected
the module is called a whelan alpha 12x
does anyone know anything about this?
only thing I can do is try to reconnect it all another day
Some of those reset after you've driven the car, have you done this?
They should go off after a short drive in a straight line.
Just remembered
after putting the battery on accidentally sparked the battery after catching the body and it banged
perhaps I've blown the relay or fuse, but I wouldn't have any power steering if it has blown surely
Edited by lDanl
Havent actually driven it yet will see what happens on the way to work
I think it all resets within less than a 100 metres, as Rustynuts said needs to be in straight line.
Cheers, as you both said it has reset as it got to the end of the road
mot is next week so was feeling nervous lol
Happens every time you disconnect the battery, don't worry.
