Admunson Sat Nav Display........
Whilst using Sat nav on the Admunsun unit is there any way to remove the directions from the Maxi Dot and just listen to the Instructions from the unit.
I like the big digital speedo instead of the directions being displayed
Thanks in Advance
AG
Can't you just hit the far right return button on the steering wheel and scroll back to driving data?
Mmmmm...........Every time I hit a MFSW button it asks if I want to Exit sat Nav.
Might try that tomorrow Leon, hows the Vrs ?
Good thanks trying to keep my money and not change anything! It shouldn't cancel the navigation. It just allows you to change the display in the colour maxi dot. Give me a call if you get stuck! :)
Will do mate, thanks
AG
This should work, that's what I do. I have Columbus rather than Amundsen but it should just work the same :)
Hi,
Don't use the scroll wheel, press the button to the right of it, then use the scroll wheel to select the screen you want to view.
Problem sorted folks
AG
