VCDS 15.7.1 - 17-INSTRUMENTS
Hello.
Om my VCDS 15.7.1 i found on my Octavia one item that i want to know if it possible to unlock:
On Central Electrics - 17 Instruments - is has an item, (5) Hiden bits.
To unlock it is needed a code for security acess.
Any one know what code is it?
Best regards,
Sérgio Bessa
Your vcds needs updating first, you're a couple of years out of date.
If update it it wil "blow up"...
Ah, I see.
You should buy the genuine item then. That would give you technical support from Ross Tech who know most (if not all) of the answers.
Sorry but you will get no support here with hacked versions.
Thread locked
  • Gizmo locked this topic
Guest
