vcds fault code
after a vcds scan i got this fault code on 47 soundsystem:
1 Fault Found:
1559 - Cooling Fan for Housing
          B126B 01 [008] - Electrical Failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 12
                    Mileage: 18414 km
                    Date: 2017.02.11
                    Time: 13:53:19
                    Voltage terminal 30: 14.6 V
enyone know what this is and if this can be related to the infotaiment freeze and strange behaviour on cold days..
I think it is the fan that cools the infotainment unit, sometime it is not working
