Fault codes?
Hi
Just pulled out the driveway and noticed EML on
Checked the obd and got
P0030...current fault
And
P0135...pending fault
Am i rite in thinking change the O2 sensor
Or is there a few sensors it could be pointing toward
Will have a look round the forums when get back.
Just thought id put this up for now
1 hour ago, kentphil1 said:
It is highly likely to be the pre cat lambda sensor, but I would check the wiring plug under the floor first for any damage or crud to be sure.
http://wiki.ross-tech.com/wiki/index.php/16414/P0030/000048
Will have a look but certainly seems like in most cases the pre cat sensor needs replacing. Has little over 180k miles on it so lasted well
Thanks for the reply
If it had of said Bank 1 sensor 2 would that have pointed to the after cat sensor? Rather then bank 1 sensor 1 i mean
Edited by huwants2no
  • 4 weeks later...
Sorry, must of missed the post for some reason, and the answer to your question is yes, Bank 1 Sensor 2 is after the cat, sensor 1 is before the cat. Can't help on the sensor in your link, when my one left the planet, I fitted a bosch, which I think is OEM from memory.
No worries. Thanks. Think ill try get a more reputable one. The difference in prices is fairly wide tho
  • 4 weeks later...
Should the fault code and eml disappear if problem sorted or do you always need to clear the codes?
