VAG-COM codes interpretation.
Hello! I recently did a scan on my car and come up with these problems, I did a fair research of what they mean but did anyone encounter them and found an easy fix or do they need replacement?  Thank you!
Address 01: Engine Labels: Redir Fail!
Part No: 03E 906 033 A
Component: 1,2l/4V SIMOS3 00HS5329
Coding: 00071
Shop #: WSC 13765
VCID: 1E3338F39A420EEE86F-5072
TMBPY46Y844133356 SKZ7Z0D2558134
4 Faults Found:
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
17811 - EGR System
P1403 - 35-10 - Regulation Deviation - Intermittent
17811 - EGR System
P1403 - 35-00 - Regulation Deviation
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 R HW: 6Q0 907 379 R
Component: ABS 8.0 front H03 0001
Coding: 0000005
Shop #: WSC 13765 000 00000
VCID: 4C9782BB2C3ECC7E38B-5000
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F2EBBC43BE5A7A8E127-5072
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25626
Shop #: WSC 13765
VCID: 3C77D27B2C9E7CFE88B-50E6
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 0S AIRBAG VW51 0008
Coding: 12371
Shop #: WSC 13765
1 Fault Found:
00532 - Supply Voltage B+
  • Sponsor
17811 is the EGR valve not doing what is requested (sticking).
01596 is fairly standard, recirculation flap motor/potentiometer fail; there are probably more mk1 Fabias on the roads with this fault than without it.
Battery voltage faults are common too. May be an old battery, may be a charging system fault. Check to see if the battery light comes on with all the other warning lights when you turn on ignition.
  • 5 months later...
Hi, I have problem with understanding of fault codes. Does anybody can tell me where fault code really is? Also I would be very, very grateful if anybody interpret these faults.  Please take a look below:
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5E0 920 871 B    HW: 5E0 920 871 B
   Component: KOMBI         333 2210
   Coding: 07AC02002980000801087A00040000
   Shop #: WSC 73430 031 00205
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
   VCID: 2744EB4F0FEDEDBA7EEA651-8072
2 Faults Found:
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 45040 km
                    Date: 2017.08.12
                    Time: 13:22:48
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 45040 km
                    Date: 2017.08.12
                    Time: 13:22:48
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001788225
   Coding: 030100042F085700EF00024A080F00010001050000000000000000000000
   Shop #: WSC 73430 790 00205
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear.rod
   VCID: 3F94532FF77D457A261A6D1-806A
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5E0 919 719     HW: 5E0 919 719
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000C1238110114
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 4408213103
1 Fault Found:
131602 - Power Steering Control Module
          U101D 00 [008] - No Communication
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 45160 km
                    Date: 2017.08.15
                    Time: 14:46:02
