Replacing rear spray nozzle
Discovered that the rear washer spray nozzle is missing. Dealer also sending to me to fit.
Is this an easy job or should I get garage to do and charge dealer.
Easy, remove the rear wiper arm cover (the bit that's covering the nut that holds the arm on.) Then push the new nozzle in aligning it so its vertical, then replace the cover ..... job done.
They do seem to "pop" out easily, I only noticed it when we started washing the road instead of the rear window.
Hope it helps :)
Thanks Truckbus you make it sound easy so will give it a go when it arrives. Cheers.
