Rear hatch stuck shut
Had a problem with rear hatch stuck shut, display showed hatch open fortunately by pushing down on the door and pressing the door switch it opened. Can it be opened from the inside on my old 55 plate Fabia estate you could climb into the boot and access a switch under a small removeable panel. Joe
do you have autolock enabled? do you press the door unlock button twice to unlock the boot?
