Start/Stop
Nope. Slightly related, there is an option in OBDeleven (I forget the exact menu) to deactivate the start/stop function. For those who know OBDeleven, it's not an app but in the actual adaptations. I was never brave enough to try it though.
I've disabled S/S on my 1,8tsi with Carista app and a generic obd plug. It works fine ;)
That fix is just altering the battery voltage limit where the S/S won't engage. The OBDeleven adaptation seems to be more than that, at least that's what I was assuming. I have no real basis for that assumption.
And ? The voltage trick is the easiest and least intrusive in IMO.
OBDeleven
Disable stop/start
1) Select Control unit 19
2) Select Adaptation
3) Select Stop start limit voltage
4) Change value to 12 (default is 7.4)
5) Press the green tick to confirm
the easiest and best way
I will order it (55€) and let you know
