Sensor probes on exhaust
How easy is it to change yourself been quoted 265 pounds by skoda garage
What :eek:
The sensors are about £90.00 ish + VAT each.
There are 2 pre cat and after cat.
But if you can get under the car it is not that hard.
Just make sure the exhaust is cold.
Sarah
Cheers sarah
So you are saying that it is easyto change yourself? got the parts for
Hi
So your fitting both?
They bolt in to the exhaust and just follow the wiring from the old ones.
Just plug in the other end IIRC
Sarah
what's the IIRC
IIRC = If I Remember Correctly.
I would thought you would only need one, number 1 probe before the cat.
22mm spanner of if they are tight a deep socket is required. The connect underneath, you have to remove the black plastic cover on the plugs under the car (o/s).
