Full lights failure!
Hi All,
Hope someone can help with this!
I switched my octavia vrs estate off at the petrol station and when I turned it back on it told me to check every light and there is an issue with each one!
Indicators only flash on wing mirrors otherwise they are solid
dipped beam doesn't work
neither do my brake lights, headlights or number plate lights!
Can't find any other similar issues, anyone come across this before?
Christian
Disconnect the battery for a full system reset.
If this doesn't work then it is likely the BCM / CECM (lighting control module) is playing up and might need replacing.
It may also be worth checking the light switch cluster. Mine went south last year. Symptoms weren't the same, I just could no longer turn off the low-beams nor use the fog lights.
