Suspension top mount bearing part number
Hi all.
Need to replace my top mount bearing on the drivers side.
I read a thread on here dated a few years ago with a load of part numbers on for the bit I need but wanted to double check.
When end I called skoda they didn't give me the part number but said I need the nut to go with it the 3 bolts and the bearing and cup come as 2 pieces. Total charge £65 inc vat for the part.
can anyone point me in the right direction for the complete top mount bearing bit i need. Not just the bearing but the whole bit.
Its for a 2007 vrs.
Thanks.
Cheers mate. I only need the one. I know with springs you change both but is it really necessary to do both bearings?
If your only replacing one spring I'd only change that top
mount
I was replacing all shocks and springs anyway so did Top mounts and bearings with them
are both side the same, or are they specific? Have been seeing some that end with B and some end with C?
thanks
Both the same
Thanks. Part ordered.
