Mirrorlink
Hi,
Anyone tried mirrorlink or carplay in skoda rapid 2017 model?
On 6/22/2017 at 16:23, Sujeeth said:
Hi,
I have tried Carplay in my Skoda rapid 2014 fitted with RCD 330g plus
Everything works perfect except maps. Currently apple is not supporting navigation for CarPlay in india
  • 2 months later...
Hi,
I have tried to connect my car (model year 2017, infotinment Swing) via mirror link but unfortunately my phone (Xiaomi Redmi3) is not supported.
So I had to use another way...Andriod Auto. And this app is not working correctly. Is not possible to use navigation....it doesn't work correctly and I don't know why.
I want to try different USB wire...but I don't believe it will help.
Edited by VictorCZ
20 hours ago, VictorCZ said:
Hi,
Hi VictorCZ
I'm not sure whether Xiaomi supports mirrorlink. You can check the compatibility http://www.mirrorlink.com/phones
Your phone should support VNC protocol.
Hi Manoj1135,
Thanks for the link but I have already visited this link and I know that my smartphone is not supported. That's way I use the app Auto Android.
BTW...today I have found why my navigation doesn't work. The problem wasi in setting smartphone.
But there is another problem....after I disconnect smartphone and car and try to connect it again, the app AA stops to work. So I have to reboot my phone to be able to use navigation again.
I think it is my smartphone's problem.
  • 2 months later...
Which version does your headunit run? can you share the snapshot of the system information?
Did you get the carplay update from the service center?
