octavia 2010 door lock barrel removal problem
HI THERE IM HAVING DIFFICULTY REMOVING THE DRIVERS SIDE DOOR LOCK BARREL
IVE REMOVED THE TORX SCREW THAT YOU NEED TO REMOVE THE SMALL PLASTIC GROMETS TO ACCESS AND THE BARREL IS STILL SOLID IS THERE SOMETHING ELSE THAT I NEED TO DO IN ORDER TO REMOVE THE BARREL ?
AS I CANT LOCK OR OPEN THE DRIVERS DOOR DUE TO THE LOCK JUST SPINNING AND NEED TO USE THE PASSENGERS SIDE TO DO THIS
ANY HELP OR SUGGESTIONS WOULD BE MUCH APPRECIATED
CHEERS RAB
  • 7 months later...
@rabbydo did you ever solve this?  I'm in the same position but I'm not sure if I know the right screw to remove and how much to unscrew it.
Can you help please?
See here...
