Parking Assistance- Control module not coded Fabia 2010 1.2tsi
Hi Guys,
My friend bought this Skoda Fabia 1.2tsi (estate 2010 reg). He got parking sensors on the back of the car but they do not work..after being diagnosed with my OBDeleven tool..I found the following fault code
U101300 - Control Module Not Coded. Can anyone tell me how to code it for parking sensors..thank you.
Edited by automass
Well, it seems like it's not coded.
id simple check the options selected with vcds and go from there.
Thats what i need direction for. where to go and what to look for? thanks for your reply though.
No problem, do you have access to VCDS? (Vagcom)
If not then you need to find someone that does for now.
yes i have obdeleven. it can do code and everything.
Have a look in 09 - central electronic and check the options selected, check the car still knows its got parking sensors fitted
I don't have real vcds..but OBDEleven..what I can do is if I can find the code and the guideline about how to input it that would be great.
I thought that you implied that obdeleven could do this, if so maybe find an obdeleven user's forum as it should tell you all, most people seem to prefer VCDS as it is kind of quite handy.
