P0302
Anyone had this fault recently?  Misfire in chamber 2.  Ive changed plugs but no difference.  Next stop the coil pack im guessing?
Engine has a stutter at about 2800 revs under load.  Hope this is all linked!
2.0 tsi vrs.    2010. 45000 miles.
Swap the coil packs around. If the misfire stays in the same cylinder, it's something. If it moves with the coilpack, you can be confident it's the coilpack.
I hope the stutter is linked too, but it seems a stutter/hiccup at that rev range is common :/ I've still never got rid of mine and I'm currently investigating one way valves on the pipes linking the turbo and intake manifold flaps.
Edited by planehazza
Ive got the same problem on same cylinder but a 1.8tsi engine. Ive renewed all 4 plugs & coil packs. Also checked compressions. The only thing left is injector or its wiring fault that i can think of.
