VCDS fault log off car shows wrong time/year
Hi All, I did a scan the other day and noticed VCDS said it was from 2011 and it happened last week ! so will VCDS update the cars logging clock ? the laptop clock is correct so it mustn't  use that as a reference. cheers Stuart
What car was this on?
Most of the non MQB (Octavia 3, Superb 3, Kodiaq) cars the dates VCDS shows are way out.
Sorry for the late reply Gizmo, It was done on my Octavia FL Scout 2009 TDi , so is there anyway of putting the correct time/date/year ? cheers Stuart
I'm not aware of anyway it can be changed.
Thanks for the reply, I will have to work out how far behind it is and add it to the time and date VCDS comes up with, its just annoying that it shows a fault log from 6 years ago that you could delete, when it actually occurred in the last few days ! cheers Stuart
Is the time shown correctly on your infotainment and/or instruments in the car?
Sorry for the late reply, the standard display of clock time is correct in the centre dash if that helps. cheers Stuart
