Coolant loss only when heater on.
I m losing coolant but only when heater is on.
I got the low level warning 12 months ago. Topped up and it went for  a month
Put some radweld in and it went for 3 months.
The coolant drips from front bumper right side after a run on a hot day.
From time to time I noticed the curry smell in the car.
Recently I noticed that smell as I set cabin temp up from 19 to 24.
The leak Is related to the heater being turned on.
There is pink residue  on a component inboard from coolant reservoir and lower down.
It has what looks like a hex cap on top.
Difficult to see this item under a mass of pipes. What is this part.
Any of above sound familiar?
Peter
I have found the leak.
It is a y shaped connector between expansion tank and engine part 1J0121087E
After a run on a hot day the heat soak raises system pressure and coolant squirts out of a hole in this plastic connector.
A new aluminium one is on order.
PeterGAH
Aluminium y joint now fitted.
Petergah
