Interchangeable Brake Master cylinders?
When removing the master cylinder as it was taken out is sounded like it was drawing air in, then once refitted it then started hissing when pushing the brake pedal, while the engine was off. What does that make you think?
39 minutes ago, Martin191 said:
Also to add to this - both the bleed nipples have sheared off the master cylinder.
This says you need a new master cylinder anyway. Hissing noises still sound more like pneumatics than hydraulics to me though.
