4x4 Oil Change
I bought my Yeti new in 2011 and the same dealer has carried out all the servicing (variable).  I have just received an email telling me that it is time for the 4x4 transmission oil to be changed.  I thought that changing any oil was part of the regular servicing, but apparently that is not so.  The car has done 66000 miles and I wonder if this oil change should have been carried out some time ago?  I am also concerned that there might be other maintenance of which I am not aware.
Do you have DSG gearbox?
No, it is a manual box.
Do they mean the Haldex?
This is what I received
Your ŠKODA is an intricate, finely-tuned piece of engineering.
A prime example is your all-wheel-drive system’s electronically controlled
multi-plate clutch, and our records tell us it’s about time yours had some routine maintenance.
Your drive system uses a high-grade oil to protect and lubricate it and the only way to ensure it stays ticking along nicely is to change the oil and filter every now and then.
The cost is £69 for 4x4 transmission oil change.
^^^ Bargain. Much Cheapness infact.
Pity that Service Desk Staff do not let all owners know what a vehicle with Haldex needs in the way of servicing @ 40,000 miles and many owners are making the manufacturers warranty or extended warranty void by not servicing to Manufacturers Schedule ie 40,000 or even 30,000 miles
Brake fluid change at 3 years then every 2 years, or at least checked for H2o content.
Extra Charge not part of Service Plans or Minor or Major Services.
Edited by Headinawayoffski
Now that's exactly the answer I was looking for.  Many thanks.
Would be interesting to see if that £69 does actually include the filter change, that the preceding text suggests is necessary :)
Edited by muddyboots
I asked if the filter had been changed and was told that unlike the DSG, the Haldex doesn't have a filter.
