Hadbrake on indication and beep?
Hi there, when i pull my handbrake indication light on dashboard goes on, but is there any beep when you try to go with handbrake pulled?
I remember that is used to beep and no it doesn't, is there something wrong?
And what can it be?
It will only beep if you're still moving.
The handbrake light will light up and you’ll get s beep if your drive with it on for more than a few feet and over a certain speed.
Tested this evening, distance triggers it. Thanks for advice.
