Tools, nut size rear bearing swap
Which nut size is the rear wheel hub nut? Also which size is the umbraco screw head for the rear caliper. I'm changin the rear wheel bearing to swap for a new hub with bearing fitted, I have a three armed puller. Anythinh else I need other than a torque wrench, someone remember the torque spec?
Here is the repair procedure for the rear bearing. The rear calliper carrier you can leave attached to the hub, the rear disc will come off without removing it. To release the rear calliper you will need a 13mm and a 15mm spanner (I think) to undo the slider, calliper will then sit out of the way.
rear bearing.pdf
  • 4 weeks later...
What kind of puller can I use for the inner race?
