problem with car DSG Mechatronic or Transmission
Hello,
I have problem in my transmission of my Skoda ocatvia 2011 1.2 tsi  Model: 1Z32DD Engine type: CBZ, chassis Number: TMBCM61Z9B2137172.
When I change the gear to D, the D sign start blink and the car doesn't move.
I attached here the VAG-COM log
can someone help me?
what is the part number of the Mechatronic? are there any other parts that I need to buy?
can someone send me link of reseller of the OEM part?
I saw these parts:
http://www.ebay.de/itm/AUDI-VW-SEAT-SKODA-DSG-DQ200-GETRIEBESTEUERGERAT-REPARATUR-/263226866529?hash=item3d498b3b61:g:omcAAOSw~ZBZwM6I
http://www.ebay.de/itm/AUDI-VW-DSG-7-Mechatronic-ECU-unit-Gearbox-0AM927769D-/172816892476?hash=item283cb0823c:g:q6IAAOSwi69Z0Msn
can someone tells me what are these 2 pumps? should I buy these pumps too? and if so what are the part number?
Shlomi
VAG-COM log:
Friday,13,October,2017,18:10:09:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
Dealer/Shop Name: Skoda East Jer
VIN: TMBCM61Z9B2137172   License Plate:
Mileage: 130100km-80840mi   Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCM61Z9B2137172   Mileage: 130100km-80840miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 S    HW: 03F 906 070 F
   Component: SIMOS10.10H03 9844
   Revision: --------    Serial number:
   Coding: 002500D6230400080000
   Shop #: WSC 73430 031 00092
   ASAM Dataset: EV_ECM12TFS02103F906070S 003014
   ROD: EV_ECM12TFS02103F906070BF.rod
   VCID: 32720B5B342F9812D994FCD-8066
1 Fault Found:
6260 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 6
                    Mileage: 125694 km
                    Date: 2017.08.12
                    Time: 23:35:08
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 050 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2668
   Revision: 00043014    Serial number: CU501307096116
   Coding: 0000020
   Shop #: WSC 00027 127 00003
   VCID: 32720B5B342F9492D994FCD-8066
6 Faults Found:
006079 - Hydraulic Pump
               P17BF - 000 - Play Protection - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 14
                    Reset counter: 10
                    Mileage: 129478 km
                    Time Indication: 0
                    Date: 2012.02.29
                    Time: 16:24:16
               P17BF - 001 - Play Protection - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 14
                    Reset counter: 10
                    Mileage: 129478 km
                    Time Indication: 0
                    Date: 2012.02.29
                    Time: 16:24:16
               P17BF - 002 - Play Protection - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 14
                    Reset counter: 10
                    Mileage: 129478 km
                    Time Indication: 0
                    Date: 2012.02.29
                    Time: 16:24:16
002113 - Transmission Fluid Pressure Sensor/Switch 1
               P0841 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 8
                    Mileage: 129659 km
                    Time Indication: 0
                    Date: 2012.02.29
                    Time: 18:15:28
054272 - Function Restricted due to Insufficient Voltage
               U1400 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 0 km
                    Time Indication: 0
006300 - Function Restriction due to Insufficient Pressure Build-Up
               P189C - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 129971 km
                    Time Indication: 0
                    Date: 2012.03.04
                    Time: 08:25:32
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B201C09250001880C04EB901B0040350000
   Shop #: WSC 73430 790 00064
   VCID: 76FAF74B98C7C4B235FCC0D-8022
No fault code found.
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 R    HW: 3T0 820 047 R
   Component: AC Manuell    H16 0401
   Revision: 00007001
   Coding: 0000000002
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_SK35.rod
   VCID: 3E6A2F6BF0774C722D0C78D-806A
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AD
   Coding: 40000AB8A00508C04010008011000024472000AE524D89605CC440000040
   VCID: 2F74022F271DB57AB6BADD1-807A
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 12031  26  0601
   Coding: 00D7B7
11 Faults Found:
02395 - Parking Light Front Right (M3)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 143
                    Reset counter: 214
                    Mileage: 114695 km
                    Time Indication: 0
                    Date: 2011.06.28
                    Time: 12:25:18
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
02394 - Parking Light Left Front (M1)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 22
                    Reset counter: 253
                    Mileage: 124364 km
                    Time Indication: 0
                    Date: 2011.12.17
                    Time: 19:38:23
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.40 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 19
                    Reset counter: 238
                    Mileage: 127216 km
                    Time Indication: 0
                    Date: 2012.02.01
                    Time: 22:22:32
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 249
                    Mileage: 129825 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 03:26:06
             Freeze Frame:
                        Term 15 On
                    Voltage: 6.30 V
                        ON
                        OFF
                        Term 50 Off
                        OFF
                        OFF
01501 - Bulb for Blinkers; Rear Left (M6)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 223
                    Mileage: 127789 km
                    Time Indication: 0
                    Date: 2012.02.13
                    Time: 02:28:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
01502 - Bulb for Rear Fog; Left (L46)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 223
                    Mileage: 127789 km
                    Time Indication: 0
                    Date: 2012.02.12
                    Time: 22:47:53
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.55 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
01518 - Bulb for Back-Up Lights; Left (M16)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 223
                    Mileage: 127789 km
                    Time Indication: 0
                    Date: 2012.02.12
                    Time: 22:47:53
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.55 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 31
                    Reset counter: 214
                    Mileage: 127789 km
                    Time Indication: 0
                    Date: 2012.02.12
                    Time: 22:47:53
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
00153 - Windshield Wiper Motor;  Driver Side (V216)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 252
                    Mileage: 129825 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 03:26:14
             Freeze Frame:
                        Term 15 Off
                    Voltage: 8.70 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00154 - Windshield Wiper Motor;  Passenger Side (V217)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 252
                    Mileage: 129825 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 03:26:14
             Freeze Frame:
                        Term 15 Off
                    Voltage: 8.70 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
01598 - Drive Battery Voltage
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 249
                    Mileage: 129836 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 04:51:46
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC245DSE
   Coding: 0020790
   VCID: 3D682867FD715BEA3406779-8068
   Subsystem 1 - Serial number: 6332MSME5D710A5EQ
   Subsystem 2 - Serial number: 6342MSME5C3500412
   Subsystem 3 - Serial number: 6351HSME266E190AF
   Subsystem 4 - Serial number: 6361HSME266E065DK
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 AN    HW: 5K0 953 569
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110310101278
   Coding: 5880000000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 78E6F97392D3B24227D0FE5-802C
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 803 K    HW: 1Z0 920 803 K
   Component: KOMBI         H05 0405
   Serial number: 00000000000000
   Coding: 110801
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 3C6E2563E66B5E620338425-8068
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 160311F1000764
   Coding: 351302
   VCID: 307601533A23AA82AF80C65-8064
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0405
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AC2D33BDC7F10D2A14444D-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2119
   Coding: 0000244
   VCID: 488649B3A2B30E4297B0CE5-801C
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revision: 00H20000
   VCID: 347E0D43CE3B9AA2CB68EA5-8060
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    Battery Volts: 12.1 V
                        PD
                    Temperature: 36.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000244
   Shop #: WSC 00045 730 82042
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2L9041669
   Coding: 050002000001
   VCID: 317004573129A38AA08ECB9-8064
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 249
                    Mileage: 0 km
                    Time Indication: 0
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 91682 km
                    Time Indication: 0
                    Date: 2016.03.15
                    Time: 12:30:14
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 337C0E5FCB359D9AD262E11-8066
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
            008 - Implausible Signal - Intermittent
00108 - Signal Central Locking SAVE/LOCK Rear Right
End-------------------------(Elapsed Time: 01:56)--------------------------
Edited by mrblue001
^^^ Do you need to buy any parts.?
Has your car had '34F7' carried out ?, do not let Skoda tell you the car is out of Warranty,
the DQ200 had and has funbdamental design, manufacturing and component / oil failings and software, they are still responsible in many cases.
There was a World Wide Recall on the DQ200, this excluded Europe that just got a Service Campaign.
Never got the Extended Warranty or New Mechatronic Control Units as the Service Campaign in New Zealand.
http://skoda.co.nz/news/dsg-service-campaign
European Owners just had the Synthetic Oil changed to Mineral and a Software Update.
'34F7'.
'34F7'.
Hi
What is 34F7?
what is DQ200?
I know they had problematic series in this model and Skoda extended the service for the gear/transformation/mechatronics to 5 years or 150,000 KM, but in my case I already passed the 5 years extended warranty.
Is there a way to contact Skoda Global services and check if this problem still under warranty ?
'34 f7'  was the Service Campaign, when it was in Regions without a RECALL.
A DQ200 is a 7 Speed Twin Dry Clutch DSG that was part of a World Wide Recall in 2012, and i countries not in the world there was a Service Campaign,
because of corrosion caused internally by VW using Synthetic oil and dodgy MCU's so was a preventative measure.
What country are you in?
I'm From Israel
How can I tell if my car is under 34f7 or the DQ200?
You have a 7 speed twin dry clutch DSG do you not, you posted links to the MCU for one.
Was your car part of the World Wide Recall (Global Recall.)  what was done did it get a new Mechatronic Control Unit then?
Does it have Mineral Oil in and a revised Software Update?
Hi
I have the DSG 7 speed twin dry clutch.
My car had extended warranty, they replace the Mechatronic on 35,000km and the clutch also they replace the clutch again at 90,000km.
I don't know if the changed the oil or did Software update.
  • 4 months later...
'34F7'.
Hi,
I'm in the UK and had fault with my mechatronic, My car model is 2011 and done 65k miles and manufactured in Czech Republic.
Do you think I'm still covered with the warranty at the link you provided?
Welcome.
Is it a 7 Speed Twin Dry Clutch DQ200 DSG?
Your Manufacturers Warranty has expired, and your car is over 6 years old so no warranty.
But then was your DSG part of the European Service Campaign and had the Synthetic Oil changed for Mineral & the Software Update due
to VW Groups fundamental design, manufacturing or materials / fluid and quality control faults?
If they paid to have that Service Campaign work done get back to them, and if the cars should have had it done and it was not get back on to them.
http://skoda.co.uk/about-us/contact-us
http://master.skoda-auto.com/mini-apps/recall-actions
Obviously Customer Services will want nothing to do with it, but then that is their default position, you need to challenge that.
4 minutes ago, AwaoffSki said:
Welcome.
Thanks so much for quick reply and help, Yes my gearbox is 7 Speed Twin Dry Clutch DQ200 DSG. I checked up my car by vin in the 2nd link but my car doesn't have and recalls. So I think there is nothing i can do with Skoda.
The problem is i already changed the mega unit to another used part, I took it from great running car but when i swapped the parts i stuck with the software. the software were at my faulty mega is  0AM 300 050 L  403 9041 and the version were at the replacement used part was 0AM 300 048 L.
I was in Skoda today they charged me £262 then they said we don't have the software was at old mega and the latest one on our system is the one ends with 048L.
My car is keep jumping and hear noise while i driving it as the software is different.
Do you have any idea how can i get the software?
With a history like that Skoda UK were never going to be able to be held responsible.
What engine does your car have,
and what DQ200 did the MCU come off of for what engine.
Was your car ever in for the Service Campaign.  is there a sticker in the boot with '34F7' on it.
I have no idea about what MCU you have fitted and if a VW Group Main Dealers Techs do not know or have the software that is odd,
best go to a VW Independent Specialist, or one of the Tuning Companies that offer DSG Software Updates for the DQ200.
Like APR.
http://goapr.co.uk
Like APR.
http://goapr.co.uk
VIN: TMBDM21Z6B2079289   License Plate: BX11 OZG
Mileage: 105550km-65585mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: TMBDM21Z6B2079289   Mileage: 105550km-65585miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Shop #: WSC 73430 031 00085
   ROD: EV_ECM12TFS02103F997035E.rod
   VCID: 326A976C65FB85D64C-8066
Readiness: 0000 0100
   Component: GSG DSG AG7     403 9041
   Revision: 00040034    Serial number: CU501011076034
   Coding: 0000020
   Shop #: WSC 59007 001 1048576
   VCID: 326A976CADFB85D64C-8066
It took the mega from 1.4TSI and my car is 1.2TSI, The parts number in faulty part matched the replaced part 0AM 927 769 D. All specialist are asking for my old mega to get the software from it and flash in my mega but unfortunately i don't have it now.
So what was that a 1.4 TSI from the likes of  a 105, 122, 144, 148/ 150 or even a 180 PS 1.4 TSI DSG, (Twincharger).
So different. Sorry i know about the 1.2 TSI & DQ200.
There are 28 variants of the DQ200 produced.
Edited by AwaoffSki
There are 8 versions of the DQ200 produced.
The 1.4TSI was 122 and my car is 105 BHP, I got crazy how is the Skoda dealer don't have my stranded/orginal version software for the mega!!
