ESP error after replacing central electronics module(09)
Hello! I'm new to this forum! I have a problem on my Fabia and i cannot find a fix for about 6 months....
I have a Fabia MK2 2009 1.2L engine 51kw BZG and i've installed cruise control on it.
The problem is that my original central electronics module doesn't support cruise control! Is 6Q2 937 049F.
So i must upgrade to 6Q1 937 049F or 6Q0 937 049F.
I've buyd both module and after installed and recoded them, with both i got the same error:
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.lbl
   Part No SW: 6R0 907 379 E    HW: 6R0 907 379 N
   Component: ESP 8.0 front   H06 0002
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002344
   Shop #: WSC 13765 790 00000
   VCID: 4088D82F109064212EF-5000
1 Fault Found:
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 177474 km
                    Time Indication: 0
And i got ESP/traction control light on my dashboard!
One thing i've did, a system test of brake using VCDS, after this everything is ok until i switch engine off. Then the error is comming back again...
Can anyone help me?
Thanks!
PS: Cruise control doas work! I've tested! Just ESP doesn't work anymore! If i install back my old control unit(6Q2 xxx), everything is ok! Except that cruise control doesn't work anymore!
Full autoscan before and after?
Before: (P1637 is because cruise control is activated but 6Q2 doesn't know this function)
Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBGH25J893130284   Mileage: 173040km-107522miles
Address 01: Engine (XXX)       Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 023 B
   Component: SIMOS91 1.2l 4VG    3015
   Revision: --H04---    Serial number: SKZ7Z0H5217080
   Coding: 0000071
   VCID: 1E344657CAA472D17C3-5000
1 Fault Found:
18045 - Powertrain Data Bus
            P1637 - 009 - Missing Message from Electric Load Controller
             Freeze Frame:
                    RPM: 0 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 28.5°C
                    Voltage: 12.24 V
                    RPM: 0 /min
                    Temperature: 18.0°C
                    Voltage: 12.34 V
Readiness: N/A
   Coding: 0002344
No fault code found.
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 5J0 820 045
   Component: Klimaanlage        X0850
   VCID: 62CC32A7EE5C163118B-5000
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q2 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 17422
   Shop #: WSC 13765
   VCID: 3F8ADBD33D6E1BD9575-50E6
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: QN AIRBAG VW51 Q5   0011
   Coding: 20814
   Shop #: WSC 13765
   VCID: 2C509C9FDC189041E27-5000
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 811 B
   Component: KOMBIINSTR.    V2802476
   Coding: 17103
   Shop #: WSC 13765
   VCID: 26446EB7C2F4AA11343-5000
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000E GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70E848EF30B0B4A19EF-5000
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2802476
   Coding: 17103
   Shop #: WSC 13765
   TMBGH25J893130284     SKZ7Z0H5217080
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10140
   Shop #: WSC 13765
   VCID: 6DD6519B27825949B59-5072
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 5J0 959 433 A
   Component: 05 Komfortgerát     0001
   Coding: 00019
   Shop #: WSC 13765
   VCID: 316E8DEBFB3AFDA9D11-49D8
End-------------------------(Elapsed Time: 04:27)--------------------------
After:
VIN: TMBGH25J893130284   Mileage: 180310km-112039miles
   Coding: 0000071
   Shop #: WSC 01973 973 01973
Readiness: N/A
   Coding: 0002344
1 Fault Found:
            P1647 - 000 -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 177474 km
                    Time Indication: 0
   VCID: 62CC32A7EE5C163118B-5072
   Part No: 6Q0 937 049 F
   Coding: 17422
   Shop #: WSC 00000
   VCID: 3D76A1DB376209C9459-5072
   Coding: 20814
   Shop #: WSC 13765
   Coding: 17103
   Shop #: WSC 13765
   Component: 0007 GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 00000
   VCID: 70E848EF30B0B4A19EF-5072
   Coding: 17103
   Shop #: WSC 13765
   Coding: 11240
   Shop #: WSC 01973
   VCID: 6DD6519B27825949B59-5000
   Coding: 00019
   Shop #: WSC 13765
   VCID: 316E8DEBFB3AFDA9D11-4A9C
End-------------------------(Elapsed Time: 04:19)--------------------------
solved by changing with 6Q1937049F! somehow, with this one is working!
