6 Speed gearbox in Estate. :)
Just done the 6 speed conversion into my estate again!
Different car, as I stupidly sold the last one in a time of weakness! :(
at least it was a lot easier this time, despite me forgetting to remove some important parts that were needed from the VRS I took the gearbox from. Ended up costing more because I had to buy those parts new from TPS.
Its well worth the change,  so anyone thinking of putting a VRS gearbox in their Fabia, these are the things you will need; (I may have done a list before)
-Gearbox
-gear cables and tower
-starter motor and bolts
-drive shafts and all bolts
-Bell housing bolts
-Flywheel bolts
-pressure plate bolts (they look the same but -the 6sp clutch uses smaller ones)
-clutch kit for 6sp
-Concentric slave cylinder
-clutch pipe (from master cylinder to slave)
-dog bone mount
-VRS Speedo (the Vrs takes its speed from the wheels, where as the 5 speed box takes its speed from the plug on the gearbox)
And then swap all those bits :)
Thanks for that quick list do you know which is the best gearbox code to go for ?
Does the clutch bolt into different holes or do you need a flywheel aswell ?
Is there anyway of re-coding the speedo instead of a new one ?
You will need the flywheel too from a 6speed box. DMF flywheel :) the 5 speed boxes are single mass as standard.
No way of re coding the Speedo as far as I am aware, much easier to just fit the VRS Speedo, I did so and just mapped out my immo
