Intake flap motor power feed.
Hi.
I know this is a common fault and I've read all sorts on most forums but still have a problem.
2007 Skoda Scout 2.0 diesel. (Not plastic manifold).
Code 08213 intake manifold runner position sensor switch.
Ive checked fuses (all of them- at least 3 times!). I've replaced unit  with 2nd hand to no avail.
My question is: What switches the intake flap motor?
I have bench tested both units and they work fine. I have power supply to the unit (2) and a good earth.
I,m thinking the green wire is the one that feeds it to make it open?
When running an active test via VAG Com and Maxi Diag i don't get any power to the green wire - unit doesn't operate?
What switches the Intake flap motor to turn on??  - I can then retrace the problem.
EGR seems to operate on active test.
Mark
