VW / VAG Washer pump 1K6 955 651- £25
I bought this thinking that the pump on my Yeti had failed so that I had the most likely part available once I had removed the front bumper (quite a task in itself).
Turned out not to be the pump, but the hose that was the issue. Consequently the pump was fitted, tested, found not to be the issue and removed.
No longer needed so up for sale at £25 ono including postage. This is a genuine VAG part (not an OEM copy) from a UK supplier.
Edited by KBPhoto
Price change
  • 10 months later...
Open to offers if anyone needs a genuine washer pump.
Is that fitted.    :thinking:
Only if you don't like  your car! Because I doubt it would go back together properly if I do it....
