LED interior lighting
My other w5w's have four small led's on the top face (face down when installed in reading light slots) plus few led's on sides.
The top ones give the extra downward facing light. Will see if i can find seller but i have had these a while now.
Any lumen spec will be BS.
  • Replies 53
  • Views 10.7k
  • If you change the number plate you may need resistors (even though canbus)    Lighting for Reg Plate festoons (had to bend contacts) you may need + 2 or 3mm width on mine   http://
  • Main Interior Light 39mm (had to bend contacts so might be better 42mm)   http://www.ebay.co.uk/itm/31mm-36mm-39mm-41mm-42mm-CANBUS-ERROR-FREE-SMD-LED-FESTOON-BULB-C10W-C5W-WHITE/14185757452
  • The main clear plastic panel is easy you just pull the front edge towards you it sort  of flips down (fingers only just press on edge) -  Then you can see all the fittings 2 x map readers + main festo
And i blew my fuse, too. 7.5
Search            CAR SIDE LIGHT BULBS CANBUS ERROR FREE T10 501W5W 8 SMD LED XENON WHITE/ICE BLUE
Seller - gadgetguysuk               These bulbs are good but their prices have gone up a little. I paid £3.49 for (six, i think).
I would now buy the eight for £4.99 if i was buying again. ;) Happy shopping.
1 hour ago, Tilt said:
Do not worry about errors unless you do your number plate ones.
search  ebay                     6x 42mm 4SMD                It will bring up the ones i purchased and they work fine. Top of list seller flcloverfaith.
ok point taken..re: errors
will check out that ebay link
https://www.ebay.co.uk/itm/6x-42mm-4SMD-LED-264-C10W-CANBUS-NO-ERROR-FREE-WHITE-INTERIOR-LIGHT-FESTOON-BULB/191999913931?epid=546181313&hash=item2cb4162fcb:g:C-MAAOSw8gVYBcHw
when you want to show a link...go to the address of the site up at the top then do a copy and paste in your thread..
that is a good deal...i am also searching that supplier for 39mm festoon as well...i need 2 for the rear seat overhead lighting...
i went to the shop and got nighties and loverly ladies wear...is that the right site...
i searched the shop but no 39mm led festoons came up
will try later again
found the 42mm leds you bought...got them under searching for led lights...got lots of christmas lights too
appreciate your info..
cheers
geof
Edited by mrcrow
the world is against us plonkers...!!!
got my 20 fuses in the post today
4 of each 7.5 up to 30
they go in the car kit now along with a screwdriver and some spanners...and a small socket set..
sometimes i have to disconnect my big battery to stop a fan running on so i keep those handy
cheers
geof
My car is pretty much full led including external lights only the brake and tail lights bring up warnings
The rear plates was annoying as canbus free should be no warnings but i got the yellow light on the dash immediately, so the same link i gave you for the rear plates sells the resistors. (Remember no plate is always on) Better to have resistors if going LED route
3 Types of Plug & Play resistors - found a pic of the ones i used VAG Type 'B' (centre one) - when you undo the number plate you can check which fitting it is.
I forgot you guys are Fabia whilst mine Octavia.
The W5W i mentioned are standard fit (with + & - as always with led's)  and these make quite good side lights as well as interior read lights in my Octy.
The length of them sits just inside the read light lens on mine, and work well.
The 42mm are fitted front and back interior and in the doors in mine.
If you check your fitting you will probably find that 42mm will squeeze in and work just fine.
I haven't been to the shop but will have a look, lol.
I haven't bothered with my number plate and there seems difference of opinion on Fabia as to error messages. Guess this depends on spec or more likely age of car.
Testing
https://www.ebay.co.uk/itm/CAR-SIDE-LIGHT-BULBS-CANBUS-ERROR-FREE-T10-501W5W-8-SMD-LED-XENON-WHITE-ICE-BLUE/161629831750?ssPageName=STRK%3AMEBIDX%3AIT&var=460904573729&_trksid=p2055119.m1438.l2649
That simple..................Cheers geof. See if i can remember next time i want to do it. I always forget about my right click button.
I think it's the 2011 model onwards where you will get a canbus error with the LEDs.
i fitted LED to my DRL using twenty20 Cree bulbs and they worked perfectly, got some canbus LEDs for the number plate off eBay and they gave the dash light error about 1 in 4 starts of the car.  I am just going to replace them for a set that have the resistor pack built in I think.
Edited by globalste
brilliant post...puts everyting into perspective
i guess since my bus is late 2008 i may not have those problems...which i want NOT!!
Cree keeps cropping up in some places i have surfed...are they different from LEDs
all i wanted was a brighter light, not really interested in all those colour options and mega light output
i am a simple chap and fear car electronic problems...:sweat:
good post and thanks
geof
Testing
thanks again...this is a massive learning curve for me...on my 2001 golf 1.6S all i ever did was to put in hight power headlights...not LED i must say...
just finished putting 5 LED downlighters in the bedroom today...wire up tomorrow...that is my speed in electrics
the car ones baffle me..
cheers
geof
thanks again
just an observation...what is the thinking about using led for the rear number plate...is it to save power?
cheers
geof
http://www.halfords.com/webapp/wcs/stores/servlet/ProductMobileDisplay?zygonManPartNum=HBU239&zygonPrice=0&zygonId=10145872&zygonArticleNum=181446&zygonGenericCode=000000&catalogId=10151&langId=-1&categoryId=165538&productId=1167239&storeId=10001
no errors here
Do you mean you got error warnings on your brake and tail lights, or that it's just the rear lights that give a warning if you change them to LED?  i was going to change my front and rear indicator bulbs to LED, not sure about the tai lights and brake lights.
interesting about those Halfords bulbs, unbelievable!!  I may go and get some if they have a trade price for them...
geof
Cree is a type of LED.  It's used an awful lot in mountain bike 24hr racing, they usually combine 3-5 together to get 2000+lumens out of them.  luxeon is the next generation and much brighter.  The twenty20 Cree bulbs will work rally well for your drls, if you want LED projectors then see AMD87s post on them.  If you want a quick and easy bright headlight then get a set of the stealth bulbs from www.hids4u.co.uk, get them in the 5000 kelvin.
Edited by globalste
The tail and brake lights give warnings. I’ve got leds in the reverse and fog and they seem fine although the rear fog and brake lights were the same red led bulbs :dry:
Must be something to do with supplying the correct current through them so that the brake lights are brighter than the tail lights?  I was half wondering how they would work if I swapped them over to LED and if I should buy white or red, looks like I will just leave it actually and swap the indicators.  I put a Cree in the reverse light and that's much better.
Thought that too although the brake lights aren’t on until you brake unless some cars where they are on then get brighter when you brake.
Must be one of those things!
Really keen on trying the new autobeam led indicators as they say they don’t need resisitors.
I was going to try the Twenty20 ones as they seemed to claim no errors, will have a look at those autobeams
Twenty20s are good have them in my drls everything else is autobeam bar the headlights which are techmax.
14 hours ago, mrcrow said:
thanks again
cheers
geof
For me its just a nicer brightness of LED vs Halogen. Been in nearly  a year now all LED's, not one has failed.
"Twenty20s are good have them in my drls everything else is autobeam bar the headlights which are techmax".
Where the Techmax a simple, no fuss fit and are they brighter then Osram Nightbreakers, would you say?  I believe the Techmax come in at around £40 but I have heard some users say they had to use a Dremel (Other small, hand held tools are available) To trim down some of the shielding to fit them in. Also, where they say turbo fan, is this ACTULLY a spinning fan or is it airflow, round a sort of helical fixture, that spins the air around, aiding cooling? I ask as I would have thought a fan would have added to wattage consumption, rather then lowering it, what is what LED fitments are all about! Brighter lights, lower power usage!
Edited by mrgf
100% brighter than any halogen I’ve put in it and it’s a proper white light.
You would need to dremil the current bulb holders or just by adaptors they are only £7/£8 and it’s an actual cooling fan.
Philips have just developed a set of H7 led headlamp replacement bulbs as well, not cheap at £150 but they pretty much just slot straight in.
https://www.ebay.co.uk/itm/Philips-X-treme-Ultinon-LED-Headlights-H4-H7-Fog-H8-H11-H16-Xtreme-Vision/382216272485?epid=2218508481&hash=item58fddd7a65:m:mi5oHqv7bPj6WQz525YtIDQ
most expensive h7's ever created? just noticed not road legal in the small print, not sure why as i am blinded by most new Audi's which i am sure is partly LED at fronts
Edited by Kobayashi
